iTwin IoT
Once you've connected iTwin Experience to iTwin IoT, you can view your sensors in real time in the Asset View.
For more information about iTwin IoT, please consult the iTwin IoT Product Wiki. This is where you will find all information related to iTwin IoT, including the widgets.
You can view the sensor's location on the asset. You can hover over each sensor for more information or its alert state. Please refer to iTwin IoT Alerts Module for more information on how to set up your alerts.
The IoT Sensors tab allows you to select a sensor and control the sensor's display settings. You can hide or show the sensors in the asset view and display a heat map overlay for your alerts.
The IoT Sensor Data Tab will show information related to the selected sensor. Select the desired sensor in the 3D view to change sensors or use the IoT sensor tab.
The IoT Sensor Data Trend shows the sensor's output over time. Hovering your mouse over the graph allows you to access a reading of specific data.
You can change the time scale from 1 hour, 12 hours, 1 day, 1 week, 2 weeks, 1 month or 1 year by selecting the appropriate option.
Access the sensor's output options by clicking the Metric/Unit Selection.
