New in PLAXIS 2D/3D Output Viewer CONNECT Edition Version 22 - Update 1
Release: May 2022
The PLAXIS 2D/3D Output Viewer CONNECT Edition V22 - Update 1 contains the following improvements and updates compared to PLAXIS Output Viewer CONNECT Edition V22.00:
PLAXIS 2D and 3D CONNECT Edition Output Viewers are available free to use. The PLAXIS Output Viewer is a standalone application intended for viewing and inspecting the results of a fully calculated PLAXIS model. This application helps you accelerate approvals and reviews by allowing project reviewers, consultants, or clients to provide feedback quickly, without the need to own or use a commercial PLAXIS 2D or PLAXIS 3D license.
