To run an AI defect detection, click the Inspections icon in the left sidebar. Then, select Inspection List from the menu.
You can open an existing Inspection by clicking on the link in the table's Type column. This will open the Inspection viewer, where you will be able to start an AI detection.
Note: If the table is empty, you will need to first Create a new inspection.
Click on the "..." icon next to the name of a supported reality data in the Geospatial widget, and click on AI detection to start a new job.
