PLAXIS Output Viewer CE V21.00 Release notes
New in PLAXIS 2D/3D Output Viewer CONNECT Edition V21 Service Release 1
Release: February 2021
The PLAXIS 2D/3D Output Viewer CONNECT Edition V21 contains the following improvements and updates compared to PLAXIS Output Viewer CONNECT Edition V20 Update 4:
PLAXIS 2D and 3D CONNECT Edition Output Viewers are now available free to use. The PLAXIS Output Viewer is a standalone application intended for viewing and inspecting the results of a fully calculated PLAXIS model, enabling the communication of results to stakeholders without a PLAXIS license.
New features
File version update
The application is compatible with the latest PLAXIS release:
  • PLAXIS 2D Output Viewer can be used for PLAXIS 2D files calculated and saved in PLAXIS 2D CONNECT Edition V21 SR1
  • PLAXIS 3D Output Viewer can be used for PLAXIS 3D files calculated and saved in PLAXIS 2D CONNECT Edition V21 SR1
Download links
PLAXIS 2D Output Viewer CONNECT EditionPLAXIS 3D Output Viewer CONNECT Edition
CONNECT Edition
CONNECT Edition
