PLAXIS Output Viewer CE V22.00 Release notes
New in PLAXIS 2D/3D Output Viewer CONNECT Edition Version 22
Release: January 2022
The PLAXIS 2D/3D Output Viewer CONNECT Edition V22 contains the following improvements and updates compared to PLAXIS Output Viewer CONNECT Edition V21.01:
PLAXIS 2D and 3D CONNECT Edition Output Viewers are available free to use. The PLAXIS Output Viewer is a standalone application intended for viewing and inspecting the results of a fully calculated PLAXIS model. This application helps you accelerate approvals and reviews by allowing project reviewers, consultants, or clients to provide feedback quickly, without the need to own or use a commercial PLAXIS 2D or PLAXIS 3D license.
New features
File version update
The application is compatible with the following PLAXIS releases:
  • PLAXIS 2D Output Viewer V22 can be used for PLAXIS 2D files calculated and saved in PLAXIS 2D CONNECT Edition V22
  • PLAXIS 3D Output Viewer V22 can be used for PLAXIS 3D files calculated and saved in PLAXIS 2D CONNECT Edition V22
Compatibility notes: Due to the major changes in the material database and the unit system, the PLAXIS Output Viewer Version 22 will only support opening PLAXIS CONNECT Edition Version 22 projects.
Download links
PLAXIS 2D Output Viewer CONNECT EditionPLAXIS 3D Output Viewer CONNECT Edition
CONNECT Edition
CONNECT Edition
