New in PLAXIS 2D/3D Output Viewer CONNECT Edition V20 Update 3
Release: June 2020
This is the first CONNECT Edition release for the PLAXIS Output Viewers:
PLAXIS 2D and 3D CONNECT Edition Output Viewers are now available free to use. The PLAXIS Output Viewer is a standalone application intended for viewing and inspecting the results of a fully calculated PLAXIS model, enabling the communication of results to stakeholders without a PLAXIS license.
With PLAXIS Output Viewer:
Note: PLAXIS Professional license is required for additional investigative and reporting features as well as for analysis.
Usage
