New in PLAXIS Monopile Designer CONNECT Edition V22 - Update 2
Release: October 2022
PLAXIS Monopile Designer CONNECT Edition V22 Update 2 (22.02.00.1078) contains the following improvements and updates compared to PLAXIS Monopile Designer CONNECT Edition V22.01:
Compatibility notes: Due to the major changes in the material database and the unit system, PLAXIS CONNECT Edition Version 22 will be installed alongside Version 21, instead of overwriting it. When running the calibration, GeoDS-projects created with PLAXIS CONNECT Edition 3D Version 21 will automatically be saved by PLAXIS Monopile Designer as a converted copy with the _converted suffix.
The PLAXIS CONNECT Edition V21 projects will remain unchanged.
New features
Built-in rule-based design models
The PISA rule-based models (Cowden Till, Bothkennar Clay, and General Dunkirk Sand) have been built into the Analysis mode. They can now be used without the need for input files.
Improved scripting interface
Improved scripting interface by adding support for generating, calculating, and viewing 3D design verification models. This enables running scripts that combine calls to PLAXIS Monopile Designer and PLAXIS 3D for automated model customization.
Fixed issues
A large number of issues have been addressed, including:
- [905575] Corrected moment value in the symmetrical 3D Design verification case
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads.
