PLAXIS Monopile Designer CE V22.00.00 Release notes
New in PLAXIS Monopile Designer CONNECT Edition V22
Release: January 2022
PLAXIS Monopile Designer CONNECT Edition V22 (22.00.00.1733) contains the following improvements and updates compared to PLAXIS Monopile Designer CONNECT Edition V21.01:
Compatibility notes: Due to the major changes in the material database and the unit system, PLAXIS CONNECT Edition Version 22 will be installed alongside Version 21, instead of overwriting it. When running the calibration, GeoDS-projects created with PLAXIS CONNECT Edition 3D Version 21 will automatically be saved by PLAXIS Monopile Designer as a converted copy with the _converted suffix.
The PLAXIS CONNECT Edition V21 projects will remain unchanged.
New features
Integration with PLAXIS 3D CONNECT Edition V22
Benefit from the latest enhancements in PLAXIS 3D CONNECT Edition Version 22 (all tiers).
Revised manuals
The manuals for PLAXIS Monopile Designer have been completely revised, and we added a full new tutorial that covers a multi-layered soil profile. The new manuals are delivered with the software (see Help menu) and available online.
Remote scripting interface
The PLAXIS Monopile Designer is now also equipped with a remote scripting interface, allowing you to create your own Python scripts for further automated workflows related to analysis setup and result data extraction.
Upgraded Python environments
Upgraded Python environments to Python 3.8.x with the purpose of fixing security vulnerabilities in included OpenSSL library.
Fixed issues
A large number of issues have been addressed, including:
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads.
