PLAXIS 2D CE V21.00.01 Release notes
New in PLAXIS 2D CONNECT Edition V21 Service Release 1
Release: February 021
PLAXIS 2D CONNECT Edition V21 (21.00.01.07) contains the following improvements and updates compared to PLAXIS 2D CONNECT Edition V20 Update 4:
New features
PLAXIS product licenses
Replaced legacy PLAXIS product options and modules by a tier-based licensing system consisting of three tiers: PLAXIS 2D (a new license type), PLAXIS 2D Advanced (similar to legacy PLAXIS 2D), and PLAXIS 2D Ultimate (similar to the full legacy PLAXIS 2D Suite).
New constitutive model: NorSand
Added the NorSand model as a User Defined Soil Model. The model is typically used to simulate static liquefaction of loose silts, the mechanism understood to be the cause of several recent tailings dam failures.
New constitutive model: PM4Silt
Added the PM4Silt model as User Defined Soil Model. The model is intended for earthquake engineering applications and liquefaction analysis on low-plasticity silts and clays.
New constitutive model: Fluid
Added a Fluid model as User Defined Soil Model. The model can be used to model water bodies as continuum elements with an appropriate constitutive model.
Tunnel import workflow improvements
Improved workflow for importing tunnel cross-sections into the Tunnel Designer. New functionality includes selecting, snapping and intersecting tunnel segments and subsections during import. This makes importing Tunnel Cross section CAD files much easier to handle and ensures proper geometric connectivity.
Calculation Kernel convergence log
Added a tool for accessing calculation convergence log files during and after calculations to gain more insight into the convergence process. This will ease pinpointing possible causes of non-convergence.
Updated Python environments
Updated Python environments to remove security vulnerabilities on some of the included packages.
Python distribution folders are now updated and default location changed to C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1 Update 1\
Technology Preview: PLAXIS LE Model importer
Some bugfixes and stability improvements have been implemented.
Renamed SOILVISION model importer to PLAXIS LE model importer
Added functionality to import PLAXIS LE, SVSLOPE, and SVSOLID material definitions and their supported parameters to an equivalent PLAXIS constitutive soil model.
Fixed issues
The following Known issue has been resolved:
Many other issues have been fixed, including:
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads.
