PLAXIS Monopile Designer licenses
Overview of functionality
In the tables below, you can find an overview of the features offered in the different Tiers, for e.g.:
Some features of PLAXIS Monopile Designer can be used stand-alone, while others require a concurrent PLAXIS 3D license, together with Geotechnical SELECT Entitlements (GSE). PLAXIS Monopile Designer can be used stand-alone with rule-based or user-supplied soil reaction curves. It requires PLAXIS 3D and GSE for numerical-based calibration of soil reaction curves, and for 3D verification.
See below the features available in PLAXIS Monopile Designer:
1D Analysis PLAXIS Monopile Designer PLAXIS 3D + Monopile Designer
Homogeneous soils ✔ ✔
Layered soils ✔ ✔
Built-in PISA rule-based models ✔ ✔
Built-in API P-Y curves ✔ ✔
Tapered pile segmentsNEW ✔ ✔
User-defined depth variation functions ✔ ✔
Force control ✔ ✔
Displacement control ✔ ✔
Modal analysis of monopilesNEW ✔ ✔
Export results as TSV ✔ ✔
Python remote scripting interface for the 1D analysis ✔ ✔
Python interpreterNEW ✔ ✔
Remote access to Python scripting APINEW ✔ ✔
Calibration PLAXIS Monopile Designer PLAXIS 3D + Monopile Designer
Generation of 3D calibration models   ✔1
Calibration of multiple ground profiles   ✔1
Calibration with target displacement   ✔1
Calculation of soil reaction curves   ✔1
Parameterisation of PISA depth variation functions   ✔1
Export to SACS/OpenWindPower   ✔1
Python remote scripting interface for calibration   ✔1
1 Requires GSE
3D design verification PLAXIS Monopile Designer PLAXIS 3D + Monopile Designer
Generation of 3D verification models   ✔1
Calculation of 3D verification models   ✔1
3D verification results   ✔1
Accuracy metrics   ✔1
Python remote scripting interface for 3D design verification   ✔1
1 Requires GSE
