Download Reality Data from Reality Management
1) Open iTwin Capture Import & Upload Tool or iTwin Capture Manage & Extract
2) In the application window’s upper-right corner, click the Manage icon and select Reality Data Management
3) In the iTwin section, click the Connect button and use the Search iTwins list to select an iTwin to download reality data from
Tip: You can type in the Search iTwins list to filter the list of available iTwins.
4)  In the Action section, select the Download option
5)  In the Cloud Resources section, select the reality data you want to download
6) In the Target Directory section, select the folder on your computer where you want to download the selected reality data
7) In the Download section, click the Start Now button to initiate download of the selected reality data
Tip: If you are using the iTwin Capture Manage & Extract product, you can batch download multiple reality data. To do so, click the Delegate to Task Manager button instead of Strat Now in the previous step. You will be able to initiate the download of multiple reality data from the Task Manager in the application's lower panel.
