iTwinCapture Modeler - Changelog (for Windows & Linux: Engine Only)
Note: The new iTwin Capture Modeler Flex and iTwin Capture Engine have been released. I invite you to subscribe to this related changelog to get the latest update from the team.
iTwin Capture Modeler 2024.1.8
Added
- New export formats for Gaussian Splat productions.
    - 3D Tiles (experimental, LOD)
    - SPZ: Niantic SPZ file, compressed gaussian splats
    - Gaussian Splats productions can be uploaded to Reality Management Portal.
Fixed
- Fixed LOD display of orthophotos and DSMs that used too much memory (could lead to crash).
- Fixed S3D "keep input resolution" option breaking classification results.
iTwin Capture Modeler 2024.1.7
Added
- Tech preview: Gaussian Splatting.
   - Added new production of Gaussian splats.
   - Gaussian Splats can be viewed in the 3D View.
   - Gaussian Splats can be edited to remove unwanted Splats.
   - Measurements on splats are available (location, distance or area).
   - Gaussian splats support geo-referencing.
- New input image file support: Phase One RAW (IIQ)
Improved
- 3D Tiles option "maximum screen space error" default value has been adjusted to improve display quality in Cesium ION and standard 3D tiles viewers (from 1 to 16). Advanced users can also edit the setting if needed in the productions settings for better viewing experience in custom Cesium viewer.
Fixed
- Fix a production crash when LOD across tiles is turned on and a reconstruction preset is loaded.
- Fix for thermal workflow failure with specific DJI cameras like the DJI ZH20T.
iTwin Capture Modeler 2024.1.6
Added
- New Feature: SDK - Camera database can now be updated through the SDK.
- New Feature: Feature extraction - extracted geometries can now be exported in GeoJson format, enabling easier integration with GIS workflows.
- Enhancement: 3D Tiles productions can now be viewed directly in the production 3D view for immediate visualization of results.
- Enhancement: Cesium 3D Tiles renamed to the new standard name: 3D Tiles, improving terminology consistency.
- New welcome screen with new video and updated links
- New photogroups handling:
   - Automatically organize photogroups by device serial numbers when importing photos.
   - Added an option to organize photogroups by acquisition date, useful for detecting multiple flights in a dataset.
   - Support position shifts in 3D view quality metrics and in the quality report.
- Regrouped detectors parameters and labels in a unique JSON file called "detector.json".
Improved
- Upload Speed: Increased upload speed for point clouds, large scans and large photos.
- Export Mapping Resource: Improved support for multiple photogroups (no longer limited to 9), allowing for more complex datasets.
- Mesh texturation and Orthophoto creation: more homogeneous coloring in areas with shadows, better color equalization.
- Improved compatibility of photographs acquired using viDoc device.
Fixed:
- Point Cloud Trajectories: Now supports UTF-16 encoding, resolving compatibility issues with certain datasets.
- Basemap Generation: Fixed an issue where basemaps is not generated from local TIFF files.
- Basemap Generation: Bingmaps basemaps are generated with bad height when changing the option "height reference"
- Fixed: photo selection is lost when switching from 3DView to the Survey Tab
iTwin Capture Modeler 2024.1.5
Added
- New Feature: Orthophoto - Added temperature map generation from R-JPEG images for thermal data analysis.
- Enhancement: Orthophoto Transparency - Produces RGBA orthophotos with no-data areas embedded in the alpha channel for improved visualization & new output format. Available for Tiff output format only.
Improved
- AT Pose Policy: "Adjust" is now the default pose policy when images have accurate initial position/rotation data
- Authentication: Authentication for Bentley cloud services is now handled directly through the CONNECTION Client at Application startup
- Terminology Update: "Share" terminology changed to "Upload," with a new upload icon for clarity
- ContextScene files now use version 6 format to be aligned with new format used by Manage & Extract and Reality Analysis Service
- Blocks can now be exported as ContextScene in any SRS to increase usability of AT results
Fixed
- Export OPC: Resolved cases where OPC files were being exported as empty
- iTwin Ready Production: Fixed production failures in Touchup workflows
- SDK Documentation: Corrected the documentation for the `importSurveyData` method
- Localization: Fixed localization issues in Bing Maps UI dialogs.
- Increased minimum GPU RAM requirement for AI jobs to 6GB to avoid failure on low end GPU
 iTwin Capture Modeler 2024.1.4 (August 2024)
Added
- New Feature: Added Microsoft Bing Maps as a basemap service.
- Enhancement: Added GroupID for uploaded iTwin Ready output in Reality Management for better organization and tracking.
- SDK Enhancement: Added "removeUserTiePoint" and "clear" functions to the "UserTiePoints" structure.
- SDK Enhancement: Added "Extend" estimation policy mode.
Improved
- Functionality Change: 3D view and survey report now use 3D horizontal and vertical error to color control points for improved visualization.
Fixed
- Bug Fix: Fixed focus loss of photo list when editing photo metadata to improve user experience.
Removed
- Removed Feature: Removed deprecated Bentley Geocoordination service.
 iTwin Capture Modeler 2024.1.3 (June 2024)
Versions: 24.01.03.100
-Engine fixes from Linux version 2024.1.2
-Fixed crash during scan collection upload to Reality Management
    -Fixes in touchup tools when mesh is built from scans
    -Fixed touchup selection not working with message "Action could not be processed"
    -Fixed crash when leaving touchup dialog
-Better display of highlighted and selected point clouds
-Fixed crash when changing the Camera projection mode in 3d views (parallel or perspective)
-Survey editing:
    -when importing, allow users to merge surveys with the same name
    -Fixed bug on adding surveys to the selected image
-AT: improve the overall fine accuracy of the "Adjust Poses" strategy.
 iTwin Capture Modeler 2024.1.1 (April 2024)
Versions: 24.01.01.100
- Fixed: 3SM productions for some SRS with foot unit
- Fixed: 3SM productions for SRS with Helmert transformation imported from DGN files
- Fixed: water contraint production for SRS with GTX
- OPC production: compound SRS are now supported
- SRS: adding Ostend vertical datum 5710 (Belgium)
- Feature extraction (Check iTwinCaptureAnalysisEngine ChangeLog.txt):
    - Getting rid of 3D segmentation jobs limitations
    - Fixing OPC format CRS
- Fixed upload of iTwinReady production: the 3sm element contains the cesium mesh (not the 3sm)
- Fixed: applying geometric constraints correctly turns productions to obsolete
- Fixed: crash when saving project after applying water constraints
 iTwin Capture Modeler 2024.1.0 (March 2024)
Versions: 24.01.00.560
- Feature extraction (tech preview):
    - New analysis types and definitions: Check release notes of the Analysis Engine (iTwinCaptureAnalysisEngine ChangeLog.txt)
    - Breaking changes: older versions (before 2024.1) of those analysis are not fully supported anymore in Modeler
    - "iTwin ready" productions can now be chosen for analysis
- New reconstruction engine
    - Fixed: flat surfaces are too noisy
    - Fixed: loss of quality in vertical structure (i.e. towers)
    - Removed "Focus on Roi" reconstruction option: not necessary anymore and handled by default
- Fixed: missing tiles in Web ready 3SM productions
 iTwin Capture Modeler 2024 (January 2024)
Versions: 24.00.00.270
- Fixed production failure when Block is in Local SRS
- Fixed 3MX production failure when input is non-georeferenced and scale constraint is used for AT
- Fixed DJI RTK import accuracy
- New "iTwin Ready" production that creates 3SM and 3d Tiles in the same time
- Easier uploading of iTwin ready productions: all necessary resources can be uploaded at the same time.
- Simplification of production formats
  - 3SM is the new default and recommended choice for use in Bentley design applications
  - iTwin Ready is the recommended choice for publication, display and analyse in iTwin
  - options simplified and default values better estimated
  - removed production of FBX format (obj can be used instead)
iTwinCapture Modeler 2023 (December 2023)
Versions : 23.00.05.10 - English
Versions : 23.00.04.30 - English
iTwinCapture Modeler 2023 (November 2023)
Versions : 23.00.03.501 - English
iTwinCapture Modeler 2023 (September 2023)
Versions : 23.00.02.84 - English
iTwinCapture Modeler 2023 (August 2023)
Versions : 23.00.01.2693 - English
iTwinCapture Modeler 2023 (June 2023)
Versions : 23.00.00.1671 - English
