| Title | Initial degree of saturation for soil activated during staged construction |
| Application | PLAXIS 2D, PLAXIS 3D |
| Version | 2024.1 |
| Original author | Micha van der Sloot |
| Date created | 20 August 2012 |
| Date modified | 05 March 2024 |
A guide to help understanding the behaviour of the initial degree of saturation for soil activated during staged construction in the Advanced Calculation Mode.
In practice, when for instance an embankment is made, the water content of the soil used to create the embankment is not necessarily equal to the water content of the in situ soil. This can be due to:
In PLAXIS, when soil is activated in a staged construction phase, users have the possibility to specify an initial degree of saturation. PLAXIS uses this saturation in the newly activated soil which defines the suction value through the retention curve. The retention curve that links suction and degree of saturation is defined in the material set parameters for that soil.
Please note that whenever the expressions initial degree of saturation and initial pore pressure are used in this article it refers to the degree of saturation and pore pressure at the start of the calculation phase, hence the initial situation for that calculation phase. It does not refer to the degree of saturation or pore pressure of the initial phase.
Users can directly specify the saturation value. The behaviour of the unsaturated soil in PLAXIS is driven by pore pressures whereas degree of saturation is the result of the pore pressures. As mentioned in the introduction above, when soil is activated in a staged construction phase, it will by default follow the General Phreatic Level. This can be changed to Head, Custom Pheatic Level, Dry, Interpolate, User-defined pore pressure or Unsaturated. Hereafter, the effects of these water conditions on soil that is activated in the current phase are discussed.
If newly activated soil has the GPL, the initial pore pressure distribution will be according to the GPL. This implies that if the newly activated soil is
If newly activated soil has its own CPL, the initial pore pressure distribution will be according to this CPL. This implies that if the newly activated soil is
Here we have to distinguish between a UDPP of zero (pref = pinc = 0) or a UDPP not equal to zero.
If the UDPP is zero, the degree of saturation is 100%. This is based on the reverse logic and definition of a phreatic level: as the phreatic level is defined as the level where the pore pressures are zero (no pressures and no suctions), therefore it must be that where the pore pressures are zero, that is where the phreatic level will be located. Since at the phreatic level the degree of saturation is 100%, this implies that when pore pressures are zero, the degree of saturation is 100%.
If the UDPP is not equal to zero, the degree of saturation is 100% when the UDPP are negative pore pressures.
When a cluster is set to dry, the degree of saturation is assumed to be 0%.
A cluster that has been set to the Interpolate option gets the same suctions and degree of saturation as if it was set to General Phreatic Level.
Pore pressures can be generated by phreatic levels, steady-state groundwater flow and transient groundwater flow. The above mentioned options to define the initial pore pressures when activating a soil cluster in a staged construction phase behave somewhat different depending on the chosen method of pore pressure generation.
The pore pressures and degree of saturation generated according to any of the options mentioned in the previous paragraph (hence, general phreatic level, cluster phreatic level, etc.) remain constant during the calculation phase. For instance, a newly to be constructed part of an embankment that is given a zero pore pressure (and therefore a 100% degree of saturation) has a 100% degree of saturation in the whole calculation phase.
Any of the options mentioned in the previous paragraph is ignored; the calculation will always start from a distribution of suction and degree of saturation for the newly activated soil according to the initial general phreatic line.
A steady-state flow field is the flow field at infinite time. If one would deposit for instance very wet soil, the water from that soil will seep into the subsoil. Since no more water is added after activating the soil at some point all water that was initially in the newly activated soil will have sunk in the subsoil so that at infinite time the newly activated soil will have a smooth suction distribution connected to the subsoil. This is the steady-state situation. Therefore any initial situation for the newly activated soil will lead to the same steady-state solution and it is therefore unnecessary to specify any of the options mentioned in the previous paragraph and the user can simply use the default setting.
In the time-dependent analysis of pore water pressures, the initial degree of saturation is set as the initial condition of the newly activated soil layer. As time progresses in the calculation phase, saturation will change according the groundwater flow boundary conditions and material retention curves.
It’s possible to implicitly influence the initial degree of saturation for soils that are being activated in a staged construction phase. When doing so, some guidelines should be taken into account:
An embankment is constructed from soil with a degree of saturation of 70%. In order to specify this initial degree of saturation in the newly activated part of the embankment for every construction phase the saturation can defined directly by clicking on that soil cluster and then selecting Unsaturated from the Selection explorer and then specify the saturation value:
