This section contains Tips and Tricks for PLAXIS 2D and PLAXIS 3D, and answers to Frequently Asked Questions.
Accurately simulating the behaviour of rock or soil using FEA requires careful stress initialisation. For more information check this article.
In this article, you will understand the options available and the recommended action once an error occurs in the PLAXIS application.
This article explains how to use the Convergence-Confinement Method as a basic and common tool for underground support structures in conventional tunnelling during the preliminary stage of design.
This article explains how to calculate equivalent orthotropic plate stiffnesses for secant pile walls in PLAXIS 3D to represent the wall accurately in your analysis.
With the PLAXIS Calculation Log Collector, you can now inspect the convergence process in great detail, helping you to understand what is happening
After running one or more PLAXIS calculations, the PLAXIS input program will stay open. Using these tips you can automatically close PLAXIS Input.
In PLAXIS 2D it is possible to simulate a double lining (segmental or shotcrete primary and concrete secondary lining) in one of the following ways.
In this article, you can read about the considerations when modelling a thick slab as a plate.
In this article you can find information about the conversion procedure with regards to your PLAXIS 2D projects.
- vector,tunnel designer,tunnel,rockbolts,reinforcement,lineangles,line,forepoling,embedded pile,embedded beam,anchor
- tags:
It is possible for projects to have various loads being deactivated in a calculation phase. When checking PLAXIS Output results, it can happen that the visualization of the load is still visible even though the value of the load is set to zero. The load arrows may still be visible as the load is not yet fully deactivated, as ΣΜstage is not yet equal to one (1) and not all out-of-balance is solved for this calculation phase.
This article explains how to visualize displacements in PLAXIS models, including different options for displaying results.
Occasionally, PLAXIS can report lower settlements in the case of a drained analysis compared to a consolidation analysis, with the same load. Why?
When you need to apply a time-dependent radial load in a Dynamics calculation, you need to set the same Dynamic Load Multiplier for the directions.
Read how PLAXIS can be used to incorporate unsaturated soil behavior into geotech designs which can have a big impact on construction costs.
Este artículo explica los desafíos que plantea el material arcilloso al realizar análisis de estabilidad de taludes para terraplenes.
Plaxis remote scripting is built using the HTTP protocol. With correct firewall settings and password renewals, attacks can be prevented.
To save energy, Plaxis allows for an environmentally friendly (green) option to shut down your computer once all Plaxis calculations are finished: an option called gogreen. Read this article for the details.
PLAXIS Output offers the possibility using the command line to configure the plot settings in order to export a plot to a file for post-processing.
With PLAXIS 3D CONNECT Edition V20 Update 2 it is possible to generate the mesh via the command line using a series of property - value pairs.
The mechanisms and the general aspects developed in pseudo-static analysis are explained in this article, along with simple examples.
When modeling a geotechnical problem with PLAXIS a generalized approach can be followed to help avoid potential issues and maximize time efficiency.
Brief overview of the concepts of the groundwater flow analysis in PLAXIS covering cases such as dewatering, flow via an embankment, and more.
- volume,surface,stp,step,importing,import,dxf,dwg,cad,brep,acis,3ds
- tags:
In PLAXIS 2D and 3D, providing that the dynamic module is available, a dynamic (i.e., time-dependent) load can be defined by assigning a dynamic multiplier to the dynamic component of a load. As detailed later, the dynamic component of a given load is independent of its static component.
In PLAXIS, grid snapping lets you place geometry accurately by snapping to predefined grid locations, while adjusting the snap interval enables finer placement precision without changing the overall grid spacing.
Both PLAXIS 2D and PLAXIS 3D allow for multi-core calculations. This article explains how to perform parallel phase calculations in an efficient way.
PLAXIS lets users control how numerical values are displayed in Input and Output, including significant digits, decimal places, scientific notation, and result scaling, making it easier to review small differences while keeping the underlying finite element calculations unchanged by the display format.
In this video, you can see how you can easily convert your previous material databases to the new PLAXIS V22 database format.
In this article you can find information about defining and editing a material data set via the PLAXIS command line.
- structures,soils,soil,rocks,rock,plate,materials,material set,material,data set,connect edition
- tags:
This article provides a step-by-step method to derive anisotropic plate parameters for sheet pile walls in PLAXIS 2D directly from manufacturer datasheets, using the ArcelorMittal AZ 25 as a worked example.
With PLAXIS Output program a load-displacement curve can be generated. However, this is also possible with the help of the ΣMstage - displacement curve.
This article elaborates on the various options PLAXIS offers to model rock behaviour
In PLAXIS 2D and 3D, a dynamic displacement can be assigned to any cartesian component of a given prescribed displacement to define its evolution with time. As detailed below, the dynamic displacement is only prescribed to the model when both static and dynamic components of displacement are activated.
PLAXIS is now also equipped with LEM functionality: how to run a Limit Equilibrium analysis from PLAXIS 2D
- technology preview,slope stability,safety analysis,limit equilibrium,interoperability,finite element,conversion,SVSLOPE,PLAXIS LE,PLAXIS 2D le,LEM
- tags:
In PLAXIS Input, the default behaviour is to store only the last calculation step of each phase. The option to set the Max number of steps stored�can be found in Phases window, under the Numerical control parameters.
For a dynamics analysis, the user can choose several boundary conditions: Viscous, Free field, tied degrees of freedom and no specific boundary (None). With the option Tied degrees of freedom, the calculation will connect the nodes at the left and right model boundaries such that the corresponding nodes will undergo exactly the same displacements. This option may be chosen to model e.g. a one-dimensional shear column in order to perform a site response analysis.
When creating material datasets, PLAXIS offers ways to check the validity of this material dataset for soil, rock, and structures.
- validation,validate,structures,soils,soil,side panel,sand,rocks,rock,materials,material set,material,connect edition,clay,check
- tags:
This article explains how to convert the degree of saturation to volumetric water content (or vice versa) for its use in PLAXIS or SEEP/W or PLAXIS LE
When you open a PLAXIS model and the program tells you you do not have the proper entitlements, you can fix this!
In this article, we will focus on the InputSettings object that contains the information about the settings defined in Input program stored per phase.
Sometimes you want to see not only the final results of a single phase in a PLAXIS calculation, but you are also interested in the intermediate steps. Here you can see how.
How to install the latest version side-by-side to the PLAXIS 2D CE V21.01 for conversion of older PLAXIS files with the extension *.P2D.
This article explains how interface results in tables are presented as node pairs with an asterisk indicating the element considered.
This article gives you an overview of how to model rock using the Jointed Rock Model and the Isotropic Jointed Rock Model UDSM.
In PLAXIS Input, the Model explorer displays information about all objects in the model. Now it also contains information about the materials used.
- soils,soil,sand,rocks,rock,materials,material set,material,define,data set,create,clay
- tags:
A comparison between the newly introduced discrete discontinuity element and the Jointed Rock continuum model in PLAXIS 2D is made.
Two methods for simulating an NATM tunnel excavation are presented for PLAXIS 2D. Incomplete Staged construction (SC) method vs. Deconfinement method.
This article explains how to use the tabulate command to query material properties in a tabulated form with PLAXIS 2D/3D CONNECT Edition V22 or later.
The tabulate command allows showing tabulated lists of data, and the results are presented in the Command line Session window.
Set the flow and numerical control parameters for time-dependent groundwater flow analysis results within a certain time interval (Flow only mode).
Properly initialize temperatures of solid elements in Initial Phase, even if a thermal flow analysis is performed in the last phase of the project.
All PLAXIS applications support backwards compatibility. When opening an older PLAXIS project, Input program may provide some feedback to the user.
With fully permeable interfaces, the cross flow results are not shown. In the article, a workaround is shown to get these discharge values.
- semi-permeable,results,permeability,new in 3d2017,new in 2d2017,leaking,interface,hydraulic resistance,flow,drainage conductivity,discharge,conductivity
- tags:
Permeability in interfaces and the explanation of hydraulic properties of interfaces. New since 2D and 3D 2017.
- semi-permeable,permeability,new in 3d2017,new in 2d2017,leaking,joint,interface,hydraulic resistance,hydraulic properties,fracture,drainage conductivity,drainage,conductivity
- tags:
This article shows situations and considerations when modelling semi-permeable structures like retaining walls or tunnels using semi-permeable interfaces
- semi-permeable,permeability,new in 3d2017,new in 2d2017,leaking,interface,hydraulic resistance,hydraulic properties,drainage,discharge,conductivity
- tags:
- soldier pile,soil-structure interaction,secant pile,screw pile,quay wall,piled raft,pile-raft,pile,micropile,helical pile,embedded pile row,embedded pile
- tags:
This page lists the changes in the commands for PLAXIS 2D and its parameters per version.
- triangulation,tessellation,project conversion,parametric geometry,parametric,locking,intersection,import,geometry,conversion,changes,brep
- tags:
This page lists the changes in the commands for PLAXIS 3D and its parameters per version.
Information about the supported CodeMeter drivers when using PLAXIS Legacy versions. A link to the CodeMeter drivers 6.60b is available.
In PLAXIS 2D 2017 and 3D 2017, an improvement was made in structuring the properties for Phase/Step objects in PLAXIS Output program, e.g. for Python.
For PLAXIS 2D or 3D you can define a soil/rock material with a specific soil model directly via the command line or via remote scripting.
- soldier pile,secant pile,screw pile,piled raft,pile-raft,pile row,pile,micropile,installation,helical pile,embedded pile row,embedded pile
- tags:
In PLAXIS 2D and PLAXIS 3D a pseudo-static acceleration can be defined per phase. You can define the value per phase via the Model Conditions > PseudoStatic option in the Model Explorer.
This article explains how to quickly identify changes in the staged construction configuration within PLAXIS models, helping users to efficiently track modifications and ensure accurate analysis.
"This article provides examples to illustrate how to quickly identify changes in the staged construction configuration within PLAXIS models."
In this article the process of re-using materials from other projects via a global material database is explained.
When using the combination of a Safety analysis and updated mesh, the node locations will no longer be updated during this calculation. Why is this important? Read more for some examples.
Several methods to select nodes and stress points can be used for curve generation in the PLAXIS Output program.
This article explains the shear stress sign convention and how it relates to the relative movement at the interface location in PLAXIS output.
Using the built-in command line options, we can create groups based on filtering criteria that enable us to see more details of our PLAXIS model. Some examples are given for 3D embedded beams.
- tabulate,rock bolts,pile-raft,material,length,groups,groupfiltered,filter,embedded beam,commands,command line,command
- tags:
The soil test facility can be used to optimise model parameters such that the best fit is obtained between the model and the real soil lab tests.
Here we show a workaround for dealing with creep or external effect leading to overall stiffness reduction in structural elements in PLAXIS models
The difference between viewing tabulated results and curve data for structural elements is explained in this article.
With the release of PLAXIS 3D CONNECT Edition V20 Update 2, the meshing procedure is enhanced with the new Swept meshing feature!
With the release of PLAXIS V22.02, PLAXIS offers the option to directly control the tensile strength of the Hoek-Brown model
This article explains the challenges posed by clay material when performing slope stability analyses for embankments.
When running a PLAXIS 3D model, the most interesting behaviour and results are usually all inside the 3D soil model. In this article, we will show you ways how to see inside the soil and understand the results better.
New features in PLAXIS 2D and PLAXIS 3D Hydrodynamic pressure in dynamic analysis: Westergaard's added mass is now available!
This article discusses the scenarios in which orthotropic plates should be used for modeling secant pile walls in PLAXIS 3D, highlighting the advantages and limitations of this approach.
Working from home with PLAXIS [link]
See also
