Using OpenPlant PID with PlantSight
OpenPlant PID is Bentley's tool for intelligent P&ID design and in conjunction with OpenPlant Modeler makes for a great 2D and 3D combination for your project needs.  The addition of PlantSight to your OpenPlant tools gives you a great way of synchronizing your data to the cloud and being able to use that data for reporting using our iModel Data Management tools or re-use within the OpenPlant Modeler environment.
Check out this video on using OpenPlant PID with PlantSIght
https://youtu.be/CvzUBFRQLT8
