| Applies To | | |
| Product(s): | ProSteel 3D Professional | |
| Version(s): | 08.11.11.87 | |
| Environment: | N\A | |
| Area: | Part Databases | |
| Subarea: | N\A | |
| Original Author: | Jitender Sansoa, Bentley Technical Support Group | |
Problem Description
We can't generate Bill of Material for Prosteel model file.
Note : when we try to generate the Error is mentioned below. Command: _Ps_Partlist Select all parts to add in bill of material:, RETURN for all,SHIFT+ESC for Filter Select objects: Specify opposite corner: 168found
Select objects:159 Element selected 159 Element found 0 Partlist records created.
Steps to Resolve
If the ProStrucutre model is not position the user must uncheck "Verify Position number" option under partlist creation dialog box.
