Version |
v08.11.11.129 |
Operating |
Microsoft Windows® (see Requirements for specific details) |
Language |
English |
Before you begin, please note the following:
This document contains the following information:
back to top
The only changes to this release is the addition of Bentley Cloud services support for more information visit this site
back to top
ProStructures V8i *should not* be installed on the same workstation as an existing ProStructures V8i v08.11.xx Technology Preview (“beta”) release(s). Installing ProStructures V8i over an existing ProStructures V8i v8.11.xx beta installation can cause incompatibilities and data loss. You must uninstall the beta release, and then install the commercial release. Install Bentley Structural to a separate directory. You should always back up your data prior to installation.
ProStructures SS6 (08.11.11.129) is not an update release to SS6 (08.11.11.87), hence it can coexist alongside previous SS6 installation on the same system.
It is advisable to backup any customized files before uninstalling any existing ProStructures version.
ProStructures is only upward compatible, dwg files are automatically converted/upgraded to the new version, once upgraded, ProStructures objects will no longer display correctly if opened on any prior version of the software. Therefore it is advisable to make a backup copy if opening the file in its earlier version is anticipated.
For additional information on installing ProStructures V8i, see the ProStructures V8i QuickInstall Guide.
back to top
TechNotes, FAQs, and additional Bentley product information can be found on the Product TechNotes and FAQs page provided by the Bentley Technical Support Group as well as the Bentley Library.
You can efficiently log issues that you encounter in Bentley products with the Service Request Manager. Information on other professional support and service offerings from Bentley is available online at SELECTservices Online.
back to top
Meet other users of Bentley products, exchange ideas, and discuss a wide range of technical subjects in the BE Communities. BE Communities can be accessed via a Web browser and are a good source of how-to tips, technical information, and programming techniques from Bentley employees and professionals who use our products. Click here to connect with the Structural Drafting and Detailing Community Forum.
back to top
With ProStructures V8i, you are required to establish a Support Path (previously known as Registration). This Support Path connection is a one-time procedure in the form of a Web page when you open ProStructures V8i. Once the Support Path has been established, the Help > Online Support link in ProStructures V8i becomes active. This link gives you access to the Support page. Through the Support page you can manage your profile and depending on your level of support: access TechNotes and FAQs; share information on Discussion Groups; search the product KnowledgeBase; submit, monitor, and track online service requests; participate in live online chat regarding support issues; and use the latest technologies to share your desktop with a Support Engineer.
Whether or not you see the Support page depends on one of the following scenarios:
back to top
