| Product(s): | Prosteel | ||
| Version(s): | V8i; 08.11.00.19 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Derek Cornell, Bentley Technical Support Group | ||
This is a solution to add new materials to ProSteel that can be selected through the shapes dialog. The steps for previous versions of the product are slightly different.
Note: The previous versions of ProSteel required editing a *.MAT file in notepad. Unfortunately, those materials cannot be migrated automatically. Any additional materials must be manually added to the ProStructureMaterial.mdb file.
