2.5 Objectview Centered
With the feature object view centered we go a bit ahead.
You can test the function as soon as you have the first shapes inserted.
Objectview centered gives you the possibility to align the view of any
ProSteel 3D object.
Please note the element selection box after starting objectview centered.
You can either align the view to the object (a shape will be displayed horizontal)
or without this option the view will turn in direction of the object but
the alignment will be like the main view.
For this sample here the option is on.
After clicking the shape a direction symbol appears. To align the view to the web front
of the shape, click the blue arrow.
The view changes to the web view of the shape. This feature also activates the view depths front and back.
The setting of these view depths can be changed in ProSteel Options.
