5.1 Positioning Settings
Start Positioning Dialog
On Tab Steel Positioning open the Dialog for the settings
To discuss all possible settings for the positioning is not possible in this tutorial.
Please take over following settings.
You can then experiment with other settings.
Close the dialog via the ok button.
