5.2 Positioning
  1. Back in the positioning dialog set all values to start values.
  2. Start positioning for all single parts and groups and choose all
  3. Now list with single parts and groups appear. Close via ok button.
  4. Than the posiitoning is done. Dialog can be closed.
    The position numbers can be checked in the ProSteel Properties for single parts and groups.
