Now another dialog for settings opens. It should be set to preview. Start the output - butten start.
The preview will show the partlist organized by groups with a summary at the bottom. This list can be printed now. For other outputs, such as PDF, repeat the actions and choose your preferred output format instead of preview.
You can alos try other output options like single part list or bolt list.
After closing the partlist window, back in the model, all parts that have been saved to the partlist mdb will be hidden. To get them visible again perform ProSteel Regen.
