For the following sample we will use a template for Detailcenter Express. This template might not be available in all localisations. Make sure to use US/Canada localisation.
In Detailcenter start Detailcenter Express.
Open templates and load the marked template by double clicking it.
The template consists of all important settings. Just one thing makes sense to adjust. Go forward by the arrow button to pate Single Sheet Output and change the Detail output Path to a folder you'd like to use.
Now we can start the detailing of the groups.
After a while the 2d drawing creation is finished and you can close Detailcenter Express.
