| Version(s): | All | ||
| Area: | Remove Positioning | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen Bentley Technical Support Group | ||
Positioning of the existing parts is one of the last steps before final detailing of the 3D model for workshop drawings. ProSteel can do this automatically for you. It searches parts of the same type and defines their number in the model. Of course, you can also assign position numbers manually.
Deleting and existing position number
1. Click on the ProSteel Postionflags and Positioning
2. Got to the OTHERS tab.
Select the Remove Position numbers from singles parts groups Icon
Prompt: Select part:,SHIFT+ESC for Filter
Select Objects:
