ProStructures V8i (SELECTseries 8 Update 1) maintenance release includes important fixes and updates for ProSteel and ProConcrete since ProStructures V8i (SELECTseries 8)
some of the main fixes are:
| ID | Title |
| 242957 | Standard Rebar shapes from ACI_i Rebar code are always listed as managed instead of unmanaged in bar bending reports |
| 243074 | Concrete cover is maintained for stirrups in chamfered columns in the DV output |
| 243271 | Shape 7 from the RSIC code is now listed as managed instead of unmanaged in bar bending reports |
| 257802 | For solid concrete reference, all properties are listed in the the item browser |
| 261567 | Labels are always copied with the rebar using rebar modification tools |
| 268253 | Extended Stair Steps no longer clash when using Flat shapes |
| 268257 | Extended Stair Support Platform option is functional |
| 272568 | Scale factor is correctly applied to the total dimensions during the 2D update process |
| 331201 | End conditions of sloping bars are accurately represented in the dynamic views |
| 341896 | Unfolding for user shapes are improved |
| 341974 | Correct patterning is applied to plate modifications |
| 350030 | All rebar codes now include grading and coating information |
| 353461 | DXF files are now created on PW data source |
| 362139 | Group labels are maintained after manually adding rebar laps |
| 380145 | Correct surface areas for concrete solid reference objects are reported |
| 322416 | All new and upgraded ProStructures files include version control |
| 334288 | Display integrity is maintained when using reference files |
| 379549 | Solid Concrete Reference elements are published to i-models |
| 386513 | Accurate DXF output when polycut command is used |
| 388043 | Detail part weight is correctly calculated when scaled |
| 390297 | 2D detailed drawings are always consistent with the 3D model when using Detailed Center Express |
| 407955 | RebarSet retains End Condition offset upon Bar Size changes |
