| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
On the tab Holes it is possible to filter a drawing for all hole types.
The upper filter defines the type of the hole. Additional filter can be used for diameter or range.
The replace feature includes the filter. (To turn a slotted hole the filter must also be on slotted holes.)
