| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
The flyout of modifications has special tools to delete all or certain modifications.
ProSteel MicroStation
ProSteel Autocad
Note: Modifications that are created via Loglinks (endplate or baseplate connection) or structural objects (handrail or stair) can also be deleted but this can cause problems. First case is that modifications reappear as soon as the logic is updated by changing a connection or moving objects. Second case is that a connection is not working after deleting a modification. For example deleting a cut of an endplate connection would cause this problem.
