| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
On tab edges all edge modifications can be filtered, deleted or replaced.
Frame "Additional Filter" allows to search for edges of plates at the top edge, bottom edge, both as well as
top or bottom.
It is also possible to change values. This way it can be searched for facet 20x20 and replaced by facet 30x30
or by another edge.
