ISM Revit Plug-in Supported Versions of Revit TN
  Product(s): ISM Revit plug-in
  Version(s): Revit 2015 - 2017
  Area:  Import/Export
  Subarea:  Revit Version Support
  Original Author: Steve Crabtree
Bentley Technical Support Group
The ISM Revit Plug-in supports Autodesk® Revit® Structure, Architecture, or MEP, versions 2015 through 2017. Ultimate Suites of Revit also apply. Lite (LT) versions of Revit do not support any third party add-ins.
Table 1. Supported versions Matrix)
Autodesk Revit product
Supported Versions
Architecture
  • 2015
  • 2016
  • 2017
Structure
  • 2015
  • 2016
  • 2017
MEP
  • 2015
  • 2016
  • 2017
ISM Revit Link plug-in SELECTseries 6 build 8.11.11.07 or greater required for Revit 2015 support.
ISM Revit Link plug-in SELECTseries 7 build 8.11.12.03 or greater required for Revit 2016 support.
ISM Revit Link plug-in CONNECT Edition build 10.01.00.13 or greater required for Revit 2017 support. .
Some older versions of the ISM Revit plugin that work with older version of Revit can be obtained from Bentley Technical support if you are using pre 2014 versions of Revit.
See Also:
ISM Revit plugin Release Notice
Integrated Structural Modeling Home
