| Defect Number | Description |
| 261404 | Rationalized General Baseplate connection 'Align To Shape Normal' option |
| 265476 | Identical concrete shapes with differed reinforcement are assigned different position numbers. |
| 265995 | Arc Plates are exported to ISM |
| 266845 | Curved beams are exported to ISM. |
| 290750 | edge preparation is written to the NC file |
| 645171 | Three additional comment lines are added to NC DXF output. |
| 672816 | Unprocessed stepped holes in NC file are reported in log file |
| 672819 | Unprocessed countersunk holes are reported in log file |
| 687392 | multiple group property can be edited simultaneously |
| 691607 | Batch creation functions are supporting ProjectWise |
| 694598 | Deleting Pos-Numbers is also reseting the count |
| 699407 | Improved Cached View Support |
| 707806 | Resolved issues with 2D Rebar representations |
| 744564 | A new Russian dataset is added to the product |
| 747450 | The Block Center is supporting groups |
| 767095 | Resolved automatic distribution of part position flags on sheet models |
| 785926 | Improved 2D rebar resymbolization |
| 798361 | A new option is added to be able to dimension side view holes separately. |
| 811655 | Resolved detailing isometric view issue |
| 813870 | Fixed purlins insertion points issue |
| 813912 | Smartsolid on off levels no longer display in preview |
| 816822 | Stiffeners are exported to ISM |
| 857525 | Improved text scaling in Rebar Labels |
| 858402 | optimized arc plate dimensioning |
| 861120 | Resolved issues with 2D Rebar update |
| 863165 | Resolved Convert PSCE model to Native drawings or ACIS drawing on Projectwise managed workspace |
| 864035 | Resolved handrailing for Circular plateform creater than 180 degree. |
| 864266 | Improved arrow terminators in 2D Rebar Labels |
| 865555 | Optimized T shape saw length for NC output |
| 865822 | Accurate flat shapes Saw lengths are reported in NC file |
| 865883 | Streamlined extrusion of primitive PS objects |
| 884356 | Resolved issues with modeling arc reinforcement using Irregular Dispatch Reinforcing |
| 885093 | Resolved issues with opening reinforcement |
| 885094 | Resolved issues with perimeter trimmer reinforcement |
| 885705 | Implemented a new bolt weight calculation method to ignore additional parts. |
| 889126 | Group EED values are listed in the in drawing Partlist when the component is a member of a group. |
| 891767 | Improved concrete positioning including reinforcement comparison |
| 891940 | Improved 2D rebar label placement |
| 892110 | Optimized Concrete and Steel ribbon UI |
| 892787 | Optimized volweight during Partlist creation |
