| Defect Number | Description |
| 900028 | fixed copy bar label for arrow label |
| 904259 923978 933695 | 3D modeling of ProStructures objects is working with Standard MicroStation ACS |
| 910631 | resolved ProStructures crash while using modify bar with filled hidden line display style. |
| 917861 | improved bent plate AK and KA data reporting |
| 928559 | PS object center ACS is synchronized with accudraw |
| 939618 | BO block sorting order is synchronized with user hole sorting preference |
| 932720 | Public API functionality is added to obtain all properties of selected reinforcement in 3D model |
| 927479 | Landing plate assignments are stored in both template and .sve files |
| 923593 | corrected scribing (KO & PU) information for T shapes |
| 915524 | ISM import filters out unsupported entities |
| 916544 | rationalized plate NC header block |
| 911745 | resolved HyperModeling 2D bars not projected at cut plane. |
| 907280 | included T shape edge prep in AK in the NC output |
| 907303 | included M (rectangular and square tubes) shape edge prep in AK in the NC output |
| 905678 905680 905681 905683 | correct saw length is reported for I, U, T and L shapes |
| 900492 | streamlined placement of bracing beam column connection |
| 902928 | fixed copy bar label option in imperial units |
| 903173 | fixed dilimeter line label for column vertical bars |
| 903200 | Length of curved members are correctly calculated when shortened |
| 903356 | external partlist pre-verifies positioning changes before process/generating reports |
| 866876 | correct miter angle for U profile with lips is reported when both flange and web cuts are present at each end |
| 897263 | fixed rotate text 90 deg for bar mark label |
| 797072 | all annotations and dimension text containing imperial numeric values are conformant to MicroStation's dimension style stacking setting |
| 422387 | fixed the Pipe Brace slit/splice in the Dynamic Bracing |
| 809960 | streamlined text column alignment in NC File. |
| 777936 | bend plate with holes are processed and reported in the NC output |
| 901371 934547 | rationalized log file text messages including unprocessed BO (holes) block |
| 937794 | holes less than or equal to the maximum hole diameter are reported to the BO block |
| 909140 | users now can additionally export only selected objects to ISM |
| 817695 | multiple selection to substract solids is improved |
| 274530 | Shape color do change upon color change. |
| 646460 | improved reporting of IK (inner contour) for tangential circular cuts |
