| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Modifications | ||
| Subarea: | |||
| Original Author: | Johannes Michalowsky, Bentley Technical Support Group | ||
How to manipulate multiple elements, or execute the commands for modifications in loop.
2. The element modification dialog box will open. Please go to Options:
Choose you wanted Option for executing manipulation commands in loop or use the commands to manipulate multiple objects in one Go.
For example you can divide now multiple beams when you set the option "divide multiple objects"
