Table of contents
A lot has changed since the last release of v8i version of ProStructres. During this time product was improved and minor defects affecting bar location in various tools were adjusted, to make the solution more intuitive and straightforward. Most of those fixes have to do with cover distances. This means that when upgrading v8i files to CONNECT Edition, main bar location might be slightly shifted, and stirrups/ties might change their dimensions.
It is highly recommended to finish ongoing projects started in ProStructures v8i withing the same software version. To have the ability to upgrade the models to ProStructures CONNECT Edition and understand those possible minor differences in geometry and location of rebar, the Upgrade Comparison Tool has been developed.
When the tool is executed it will show a list of bars that are different compared to the original v8i model. From there users can highlight specific bars, investigate the difference, review possible difference reason, adjust it in CONNECT Edition model and update its status.
Listed below are all the known cases where upgraded models might be different from the original files. Each case contains a brief explanation together with sample images from both v8i and CONNECT Edition product versions, as well as example tool settings. Where possible, the solution to make models identical was also described.
Rebar Comparison Createattachment:
This key-in is used to create the RebarComparison dgn file and attach the same as the reference file in the model. It will not compare the dgn files but will allow users to check for differences in the model manually.
Rebar Comparison Removeattachment:
This key-in is used to remove the referenced RebarComparison dgn which is added by using key-in ‘rebar comparison create attachment’. This key-in only removes the corresponding RebarComparison dgn file out of all referenced files if there are any attached already.
Rebar Comparison Showdiff:
This key-in is used to create the RebarComparison file, attach it as a reference, will do the comparison of rebars in reference file and master file and will list out the differences in rebar, if any, with possible reason.
User Interface
Back to the top
1. Highlight Active
This option allows highlighting the upgraded rebar object in the active (upgraded to CONNECT Edition) model.
2. Highlight Reference
This option allows highlighting the upgraded rebar object in the reference (original v8i) model.
3. Isolate Selected
This option allows isolating rebar selected from the list in the model.
4. Fit Selected
This option allows fitting the view on the rebar selected from the list.
5. Export to CSV
This option allows exporting the rebar difference list to a csv file.
6. Reason Code Information
This is a link to the page containing explanations of the possible differences between upgraded and original models.
Known Differences
Back to the top
Case 1.1 Beam Main Bars and Stirrups
Location Difference, Geometry Difference, Fixed v8i Bug
V8i Defect: Incorrect cover values in v8i.
Fixed in CONNECT Edition, affecting the Stirrups leg lengths and Main Bar Location.
| v8i | CE |
Settings
How to recreate v8i model:
Adjust cover to match v8i model
Location Difference, Fixed v8i Bug
Fixed in CONNECT Edition, affecting the location of Main Bars.
| v8i | CE |
Settings
Adjust cover to match v8i model.
Location Difference, Known Issue
When only stirrups are modeled in a beam, cover values are incorrect in CONNECT Edition.
This issue will be fixed in future updates.
| v8i | CE |
Settings
Case 1.4 Beam Main Bars
Location Difference, Fixed v8i issue.
Middle bars are aligned to the corner bars, creating a gap between them and stirrups.
Fixed in CONNECT Edition, correcting the location of middle side bars
| v8i | CE |
Settings
Cannot be adjusted. Bars are modeled correctly
Location Difference, Fixed v8i Issue
When no ties were modeled in v8i and cover was set to 0, vertical bars were not respecting that setting.
Fixed in CONNECT Edition, correcting Vertical Bar location.
| v8i | CE |
Settings
Change cover to match v8i model or Tie bar size from the Ties Tab, even when no ties are modeled.
Case 2.2 Column Vertical Bars
When no corner bars are modeled In the column, middle vertical bars are slightly shifted in CONNECT Edition.
| v8i | CE |
Settings
How to recreate the v8i model:
Cannot be adjusted. This issue will be fixed in a future update.
Case 2.3 Column Vertical Bars
Middle bars are located according to the corner bars, creating a gap between them and ties.
Fixed in CONNECT Edition, eliminating the gap.
| v8i | CE |
Settings
N/A
Cannot be adjusted. Bars are modeled correctly.
Case 3.1 Pad Footing Reinforcement
When bars were distributed by Quantity, Offset value "0" was not respected in v8i.
Fixed in CONNECT Edition, affecting edge bars location.
| v8i | CE |
Settings
Adjust Offsets to bar diameter size (i.e. for #6 bar use 3/4" Offset).
Case 3.2 Pad Footing Reinforcement
When bars were distributed by Spacing and "0" value was used for both Offsets and Side Cover in v8i, bars centerline was placed on the edge of the concrete, making edge rebar stick out of concrete.
Fixed in CONNECT Edition, affecting edge bar location.
| v8i | CE |
Settings
Use negative Offset of half bar diameter to place bars centerlines on the edge of the concrete.
Case 3.3 Pad Footing Reinforcement
When bars were modeled by quantity, offsets values higher than "0" were disregarded in v8i.
Fixed in CONNECT Edition, affecting bar location
| v8i | CE |
Settings
Adjust Offset settings to match v8i model rebar locations.
Case 3.4 Circular Template Ties
Geometry Difference, Known Issue
Circular Template Ties have an imperfection in CONNECT Edition.
Known Issue affecting bar geometry. This will be fixed in future updates.
| v8i | CE |
Settings
N/A
Cannot be adjusted. This issue will be fixed in future updates.
Case 4.1 Circular Opening Trimmer Bars
Parallel bars to circular openings have an imperfection in CONNECT Edition
| v8i | CE |
Settings
N/A
Case 5.1 End Conditions of Semicircular Single Rebar and Single Rebar Distribution
Semicircular bars with bends as End Conditions have an imperfection on one of the ends in CONNECT Edition.
| v8i | CE |
Settings
N/A
Case 6.1 Semicircular Single Rebar Distribution
The issue occurs with Semicircular Single Rebar Distribution. Bars are modeled incorrectly (full circle instead of arc) and both end conditions are incorrect.
| v8i | CE |
Settings
N/A
Case 7.1 Irregular Dispatch - Multiple Arc Intermediate Points
Geometry Difference, Known issue
The issue occurs when two consecutive guidelines are used as Arc Intermediate Point in Irregular Dispatch tool.
| v8i | CE |
Settings
In Irregular Dispatch Reinforcing, remove one of the middle guidelines from the List in Main Reinforcing Tab.
