ProStructures CONNECT for AutoCAD ReadMe
Version |
V10.00.00.08 |
Operating Systems |
Microsoft Windows Microsoft® (see Requirements for specific details) |
Language |
English |
Before you begin, please note the following:
The only changes to this release is the addition of Bentley Cloud services support for more information visit this site
ProStructures CONNECT (10.10.10.08) is not an update release to SS6 R2 (08.11.11.207), hence it can coexist alongside previous SS6 installation on the same system.
It is advisable to backup any customized files before uninstalling any existing ProStructures version.
ProStructures is forward compatible, dwg files are automatically converted/upgraded to the new version, once upgraded. It is advisable to make a backup copy if opening the file in its earlier version is anticipated.
For additional information on installing ProStructures CONNECT, see the ProStructures CONNECT QuickInstall Guide.
When encountering Pipe.mnl file loads security concern message popup at ProStructures startup after AutoPLANT session is closed or any file loading security concern message at startup:
This ProStructures CONNECT version supports integration with "AutoPLANT Modeler CONNECT Edition 10.00.00.36 (Released on 05/16/2019)
Under APM CE using PS CE, please use attached file below if there are starting issues for ProStructure Structural in APM. Replace the original file from ‘Drive:\Program Files (x86)\Bentley\Plant V8i\Support’ folder with this new one.
at_struct.lsp
when encountering ProStructures dbx file loading security concern message
General Workaround:
1. In Command prompt, run SECURELOAD command
2. Enter new value for SECURELOAD '0', by default it is 1
3. Restart the session 4. It will not show any file security loading concern message at startup
Publishing ProStructures AutoCAD 2019 files to i-Model
Support and Services Information
TechNotes, FAQs, and additional Bentley product information can be found on the Product TechNotes and FAQs page provided by the Bentley Technical Support Group as well as the Bentley Library.
You can efficiently log issues that you encounter in Bentley products with the Service Request Manager. Information on other professional support and service offerings from Bentley is available online at SELECTservices Online.
Meet other users of Bentley products, exchange ideas, and discuss a wide range of technical subjects in the BE Communities. BE Communities can be accessed via a Web browser and are a good source of how-to tips, technical information, and programming techniques from Bentley employees and professionals who use our products. Click here to connect with the Structural Drafting and Detailing Community Forum.
With ProStructures CONNECT, you are required to establish a Support Path (previously known as Registration). This Support Path connection is a one-time procedure in the form of a Web page when you open ProStructures CONNECT. Once the Support Path has been established, the Help> Online Support link in ProStructures CONNECT becomes active. This link gives you access to the Support page. Through the Support page you can manage your profile and depending on your level of support: access TechNotes and FAQs; share information on Discussion Groups; search the product KnowledgeBase; submit, monitor, and track online service requests; participate in live online chat regarding support issues; and use the latest technologies to share your desktop with a Support Engineer.
Whether or not you see the Support page depends on one of the following scenarios:
