Original Question: RM Bridge to Prostructures for detail design by nguyen duc hoa
Can you show me workflow for bridge design from concept design in OBM then analysis and design in RM or Leap Bridge then detailing in Prostructures, the end is visual in LumenRT?
Thanks All
Question: RE: RM Bridge to Prostructures for detail design by Johannes Michalowsky
OBM elements can be referenced into ProConcrete and Rebar can be added directly to most of the elements. Drawings are created via dynamic views.
See also
communities.bentley.com/.../124954
Also there are special seedfiles for OBM to avoid unit issues !communities.bentley.com/.../PS_2D00_ForOBM_5F00_Files.zip
There is also an instruction how to use these and a Dgnlib.
