| Version(s): | 08.11.11.616 | ||
| Area: | N/A | ||
| Subarea: | N\A |
I am trying to get the ProstructuresOblects values of Material, ProcessStatus, and Description to display with their descriptions when generating an I-model through I-Model Composer. The come thru fine if the I-model is generated through ProStructures, but not if generated through I-Model Composer, which is a requirement for Automation through ProjectWise.
Edit ProStructure.cfg file located under Imodel composer installation folder/config\appl and unable field for "Process Status", "Description file", "Material File". see image.
| Original Author: | Jitender Singh Sansoa |
