| Product(s): | ProSteel |
| Environment: | N/A |
| Area: | Structural Objects |
| Subarea: | Common Tools |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
How to move structural objects like stairs, ladders, handrails, etc.
For moving stairs, handrails, ladders, bracings, trusses and other such objects, you just need to select the corresponding Structural Line and move that to your desired location.
NOTE: To move the structural objects when in shaded display mode, you need to enable the display of the Structural Lines.
communities.bentley.com/.../display-system-lines-of-steel-structural-objects-in-shaded-display-mode
