| Product(s): | ProStructures for AutoCAD | ||
| Version(s): | CONNECT Edition / V8i | ||
| Area: | Object Enabler | ||
| Subarea: |
N/A |
| Original Author: |
Sandip Kar, Bentley Product Advantage Group |
| Updated By: |
Vyanktesh Nama, Global Technical Support |
ProStructures Object Enabler:
ProStructures Object Enabler is a program that is required to interpret custom objects in a CAD file. If the object enabler is missing, some information in the application might not display correctly.
AutoCAD users in their structural workflow without ProStructures can still open and view ProStructures files in AutoCAD by installing Object Enabler on their workstation.
See the following Wiki :
Wiki Link: https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0103481
ProStructures Plug-in for Bentley Products:
"ProStructures Plug-in for Bentley Products" is for users who have older version of MicroStation but want to see ProSteel/ProStructures objects in MicroStation.
"ProStructures Plug-in for Bentley Products" updates "Bentley – Autodesk RealDWG" component. It is a ProStructures Object Enabler for MicroStation and suites as well for other Bentley powerplatform programs those uses "Bentley – Autodesk RealDWG" component: Bentley i-model Composer, Bentley Navigator, Bentley View etc.
Wiki Link: https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0106737
These applications and Plug in are available on the Bentley SELECTservices software downloads page by choosing "Search By: Product = ProStructures, Filter By: Download Category: Free Updates/Utilities."
But there are some situations when users don't have any Bentley software, its support or possibility to download it from Bentley Software Fulfillment center and have the need very regularly to interface with drawings/models, that are created using the Bentley software.
In order to help all our users, download ProStructures Object Enablers for required AutoCAD version and the Plug In for Bentley products, we have created this wiki article with Links without expiration date:
1. ProStructures Object Enabler for AutoCAD (2021-2024) CONNECT Edition x64 (SES) Update 2 (English)
2. ProStructures CONNECT Edition Object Enabler (v10.01.00.02) for AutoCAD (2020) x64 (English)
3. ProStructures CONNECT Edition Object Enabler (v10.00.00.04) for AutoCAD (2019) x64 (English)
4. ProStructures V8i Object Enabler (v08.11.11.207) for AutoCAD (2016 & 2017) x64
5. ProStructures V8i Object Enabler (v08.11.11.161) for AutoCAD (2015 & 2016) x32 & x64
6. ProStructures V8i Object Enabler (v08.11.11.87) for AutoCAD (2010 - 2015) x32 & x64
7. ProStructures V8i Object Enabler (v08.11.11.87) for Navisworks (2010-2015) x32 & x64
8. ProStructures Plug In for Bentley Products (v08.11.14.223)
communities.bentley.com/.../prostructures-autoplant-object-enablers-for-navisworks-2016
communities.bentley.com/.../prostructures-plug-in-for-bentley-products
