| Area: | ProjectWise Integration | ||
| Subarea: | ProjectWise Managed Configuration | ||
This wiki section:
is created to provide implementation guidance for integration of the ProStructures Configuration into a ProjectWise Environment.
is created to provide the best path to integrate ProStructures CONNECT Edition with ProjectWise CONNECT Edition.
will focus on topics concerning ProjectWise Configuration integration and WorkSet/Project association.
