Installing ProStructures CONNECT Edition
To Install ProStructures
Note: To discontinue installing the product at any time, click Cancel.
  1. Double-click the ProStructures setup executable to launch the ProStructures Installation Wizard.
  2. Optional: To make changes to the default ProStructures Configuration:
    1. Click the Configure button next to ProStructures CONNECT Edition and the Application Install Location page will appear.
    2.  To change the path where ProStructures is installed, click the Browse button next to the Application Path field and select the desired installation path then click OK.
    3. Click Next. The Configuration page opens.
    4. To change the path of Delivered Configuration, click the Browse button next to the Delivered Configuration field.
      • In the Browse For Folder dialog that opens, browse to the drive and folder where you want to deliver the default Configuration, then click OK.
      • The location of Delivered Configuration should be on the local machine.
    5. To set up Custom Configuration, select the Custom Configuration (plus Delivered Configuration) radio button. Then click the Browse button next to the Custom Configuration field.
      • In the Browse For Folder dialog that opens, browse to the drive and folder where your Custom Configuration is located, then click OK.
      • You can select a network location for Custom Configuration.
        Note: For information on Custom Configuration, refer to the topic Configuration Changes - ProStructures CONNECT Edition Update 1.
    6. Click Next. The Features page opens.
    7. In the Feature list, turn on or off any listed features, as desired.
    8. Click Done.
  3. To read the End-User Licensing Agreement (EULA), click the Licensing Terms link and the End-User Licensing Agreement will open in a web browser.
  4. After reading the license agreement, turn on the I accept the End User Licensing Terms check box if you understand and agree to the License Agreement Terms and Conditions.
    Note that agreeing to the license agreement is required install the product. Turning on the check box enables the Configure and Install buttons at the bottom of the wizard.
  5. Click Install.
  6. Click Finish.
    If you chose to use the Product Activation Wizard in the previous step, it will open at this time.
