| Product(s): | ProStructures / ProSteel | ||
| Version(s): | CONNECT Edition / V8i | ||
| Area: | Installation | ||
| Subarea: | N/A | ||
| Original Author: | Darius Rimasauskas, Bentley Product Advantage Group |
Installing ProStructures V8i (SELECTseries 5) Object Enabler alert message could appear:
“ProStructures S4 for AutoCAD is installed on your workstation. Please use the ProStructures S4
ObjectEnabler to open drawings.”
If the later version of ProStructures V8i (SELECTseries 5) will be installed on the system, the following alert will show: “ProStructures S5 for AutoCAD is installed on your workstation. Please use the ProStructures S5 ObjectEnabler to open drawings.”
This alert message notifies that ProStructures Object Enabler can only be installed on a system which does not have an existing Object Enabler or ProStructures installed.
This Dialog box says that ProStructures is installed in the machine and Object Enabler can not be installed.
Warning message installing ProStructures S6 Plug-in
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to
this "Comments or Corrections?" section. THANK YOU!
