| Product(s): | ProStructures, ProSteel | ||
| Version(s): | V8i | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Darius Rimasauskas, Bentley Product Advantage Group |
The latest version of Object Enabler should work fine of any older ProSteel/ProStructures model build in any ProSteel/ProStructures version.
DWG TrueView is not officially supported by the ProStructures Object Enabler. But if the model is saved in the DWF file format then it can be read (without understanding).
AutoCAD LT (light versions) is not valid platform for ProSteel/ProStructures and it is same for Object Enabler.
