| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
These ‘Delete Modifications’ tools are used to delete the modifications associated with the element.
In this wiki, we will learn how to use this delete modifications tools.
1. In the ProSteel toolbox, hold the left click on the third toolset and here you will see few tools regarding the modifications.
2. You can select any tool from the given box above. For e.g., we want to delete holes from a shape. So, we will select the ‘PST Modifications Delete Holes’ tool.
3. After selecting the tool, select the shapes from which you want to remove the hole modification.
4. In this way, depending upon requirement of modification which needs to be deleted, select the tool to delete that modification from the part.
