| Product(s): | ProSteel | ||
| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
PST Layout tool can be used to control the layout properties of the steel elements which are also available in PS Properties.
In this wiki, we will learn how to use this tool and the function of the tool.
1. Select the tool.
2. Then select the elements for which you want to change the properties. Then ‘layout dialog will appear.
3. In this dialog you can change the layout and hole properties of the elements. Also, you can control the other basic properties of shape like centerline, part label, pitch lines, 2D section etc. by enabling the more options from the dialog box.
