Overview:
This tool helps to filter and display the mirrored objects from the model.
Steps to follow:
1. Select the tool.
2. Now, select the parts from the model and accept.
3. This will filter and display only the mirrored elements in the model as you can see in the image below.
In this way, you can use the 'PST Mirrored Objects Tool' to identify mirrored elements in the model.
