| Product(s): | ProSteel | ||
| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
Another tool from the second tool set is ‘PST Wiki’ Tool. In this wiki, we will learn how to use this tool and function of this tool.
1. If you select the tool, the ‘ProSteel Tools Wiki’ window will appear on the screen along with the index of all ProSteel tools.
2. This window contains all the detailed information about these tools. If you click on any of the tools , the wiki about the selected tools will appear on the left side. However, there is also a help button available which will direct you to the wiki of that tool.
3. This way, you can use the ‘PST Wiki’ tool for the detailed information of any of the tools.
