| Product(s): | ProSteel | ||
| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
The level settings which are shown below are working for newly created ProSteel elements and model work.
Sometimes, there is a possibility of use of models detailed in the different versions which may have different levels assigned.
So, this tool helps to assign the standard levels and colors to elements in the model.
1.Select the tool.
2. Now, select the required elements and accept.
3. After accepting all the selected shapes will get standard levels and colors assigned.
