| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
This ProSteel tool helps to filter and display the elements depending upon their properties.
This wiki Explains the stepwise procedure to use this tool.
1. Select the tool and then select any shape in the model.
2. After selecting the shape, the Object based search dialog will pop up showing the properties of the selected shape.
3. If you double click on any one of the properties, for e.g., double click on the Part Name and this will display only the parts with the similar names.
4. In this way, with the help of available properties in the Object Bases Search dialog, one can filter and display the elements in the model space.
