| Product(s): | ProSteel | ||
| Area: | ProSteel tools | ||
| Subarea: | N/A | ||
In this wiki, we will see the use and function the ‘PST show all’ tool. This tool is present in the first toolset of the ProSteel tools.
1. The ‘Show All’ tool is basically used for regenerating the elements or to display the hidden elements.
2. Click on the tool and then ‘Show all part dialog box will appear.
3. In this dialog box, you will see different option for regeneration of the elements. You can display the hidden display classes and area classes by enabling them.
4. At the same time, you can display the levels which are off, locked, or freeze. Simply check those options and then click on ‘OK’
5. In this way, you can display or regenerate the hidden elements with the help of this tool.
