| Product(s): | ProSteel | ||
| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
This tool helps to display the all the groups one after another, along with the group properties which are present under the selection.
1. Select the tool.
2. Then select all the elements in the model and ‘Group View’ dialog will appear showing the total count of groups and its basic properties.
3. This tool helps us to display all the groups one by one present in the. Also, we can view similar groups together with the help option display together.
4. To switch the groups, you can use the options ‘Next’ and ‘Last’.
5. One can change the basic group properties from this dialog box such as Name, Note, Shipnumber etc.
After changing these properties click on the ‘Change’ button to save the changes.
